That concurs with the readings I just took - before the bypass I have 55 degree return and after the bypass the return increases to 63 degrees going back into the boiler. What a waste. I shall carry out the experiment tomorrow.
Don't forget that the boiler is not alight when on pump overrun; the water temperature will be dropping all the time; flow and return temperatures will be almost identical when overrun stops. Also the boiler may be off - flow temperature reached - but the motorized valves are still open as room not up to temperature. So there is still circulation through the rads.So at setting 2 which is 2 litres a minute that means the boiler has only 2 litres a minute flow on pump over run. Is that acceptable? Doesn't state the over run flow figure in the manual only the minimum flow during fire
