Heating works very slow recovery on DHW pipe design question
just wandering if this could be a problem with the injector T,on the return pipework off the cylinder,thats if it has one.
It does not have an injector T fitted
also yes its a soft water area
chris R any comments on the PIC yes it is pumping over at the start and then settles back very little flow
Phew cracked it
the system height (height from tank to F&E) is 7 metres, vent goose neck height was too small
fitted a longer goose neck as per instructions from plumbing book and hey presto I now have Hot water,
(I changed the filler washer in the F&E tank two weeks ago that was enough to change the mean height of the water and cause a flow problem)
Poor design overall and yes I think it was an old gravity system but at least I am back in business
thanks to all the posts it helped
cjd
whilst hot water OK recovery very slow poor flow
took out cylinder and flushed OK, only pipe left was the connecting pipe from vent to cylinder - you can see connecting pipe in picture
cut into and removed pipe hey presto it was totally blocked what was 22mm now had a 1 to 2mm hole in centre.....
replaced pipe now working like a dream with fast recovery......
:D
