The slightest interference with the boiler exhaust will cause running problems with the burner box on.....you wouldn't believe how sensitive they are.
If the flue has now been attended to, I'd look at the inspection plate on the top of the boiler (white cover off) just to see if there's any obstruction there.
The only thing I can add is that some photocells are matched to a control box, but I can't comment if that is the case here. However, if you can keep the thing on by showing the photocell light from a torch, can the cell see the flame through the blast tube?
I do think your problems are all flue related and I would also check that the baffles above the burner are clean and correctly positioned.
John
John
