- Joined
- 8 Oct 2008
- Messages
- 14
- Reaction score
- 0
- Country
Well, when I emailed the sellers (which I did before I bought one) to confirm that this appliance could be plugged straight into a UK 13A socket (with the provided adapter), this was the response I got
"Yes you can.
I sold over 200pcs. to UK without problems.
Best regards
Uhmeyer"
I came across a webiste about induction hobs and how they work, and how the power ratings for them work. I am struggling to understand whether the power (watts) of the appliance can change with a change in voltage and how that relates to the amps it draws.
http://theinductionsite.com/electricity.shtml says this:
"Keep in mind that there is no a prior way of knowing how a unit's maximum power varies with changing supply voltages: it may go down in proportion--or, if the design keeps the power level constant, it may instead go up. To clarify: a maker may say his unit takes 7,200 watts at 240 volts. Now if the unit works one way, reducing the voltage by 10% (to 216 volts) might simply drop the unit's "wide-open" power output to 6,480 watts, a corresponding 10% drop. But if the unit is designed another way, so as to keep its power steady, then at 216 volts it might draw over 33 amps so as to maintain that 7,200-watt output. It is our belief that most, possibly all, residential-type units work in the first way, what we might call the "common-sense" way: less voltage, less power. But we know for a fact that at least some commercial units work the other way, so assume nothing--ask, or do your own arithmetic."
So, by this reasoning, does the sellers claim that the unit will consume 2860w @13a 220v (in his example) make more sense ? i.e. how much power the unit outputs, and thus how many amps is draws (which is obviously the issue here), is set by the voltage it is given ? The other consideration the induction hob site brings into the equation is that the power ratings of such hobs are usually fairly inaccurate and that often the hob will not be actually drawing it's full amount of watts unless it is run with all zones on full at the same time. And even then, it seems that the maximum power of a unit in watts is not always the sum of the unit's zones (i.e. 1800w and 1600w in the case of this one) added up.
I am having difficulty understanding, using this example from the induction hob site, how the appliance will draw the same amount of amps wherever it is. I don't get how that is decided.
I know I'm possibly being thick so please spell it out for me.
"Yes you can.
Best regards
Uhmeyer"
