HELP! Jaguar 28kw Boiler not firing!
21 Apr 2008
Yorkshire
Can someone please help?
I have a 4 year old Jaguar 28kw boiler with a mind of its own.
Sometimes it will fire when you turn on the hot water/heating - sometimes it will not!
Its showing no fault, pressure is at about 2.0bar+, I thought it may be the fan so that has been replaced, worked fine for about 6 hours then stopped. You turn it of and on again (at the mains) and sometimes it re-fires.
Seems I have a fan with attitude which only spins when it wants to - could this be the APS causing this? or before I go spend more money does anyone have any other ideas???
Thanks in advance! ;)
