hmmmmIf the noise is happening with all the TRVs fully open just now then I can't see how turning them off and then on will help.
HiWhat is the Grundfos circ pump to the left of the u/stairs motorised valve for?.
Its worth turning the TRV's all off and then starting the heating to see if it is a TRV issue, then repeat the exercise by turning the TRV's on one at a time and each time restart the heating to see which one is the problem.Thanks John,
Do you think its still worth me turning the TRVs all off and then turning back on?
Ok thank you I will attempt to do this tomorrow.Its worth turning the TRV's all off and then starting the heating to see if it is a TRV issue, then repeat the exercise by turning the TRV's on one at a time and each time restart the heating to see which one is the problem.
Hi Mister Banks,Ok thank you I will attempt to do this tomorrow.
Maybe it’s the bathroom ones causing the noise, why did you leave them on?Hi Mister Banks,
I attempted this today and still the noise occurred. I did however leave the bathroom ones open.
One thing I did research is that some my TRVs are on the return pipe instead of the flow? But seeing as switching of the TRVs never fixed the problem I’m not sure how relevant that is…
HiMaybe it’s the bathroom ones causing the noise, why did you leave them on?
Ok, these are not TRV’s so shouldn’t be an issueHi
I thought because they didnt have the head with the numbers on that they didn’t need to be turned of. Will do it again with all turned off this time. Thank you
Ok do you suggest I still turn them all off alongside the bedroom rads and try this way?Ok, these are not TRV’s so shouldn’t be an issue
