However, as I pointed out then, this proves nothing - and, indeed, as I attempted to demonstrate with some guesstimated figures, the fact that a busy electrician with decades of experience hadn't seen a failed crimp wouldn't prove much, either.
There are countless possible failures of all aspects and components of electrical installations that I know do happen, but the fact that (through lack of experience/exposure) I haven't personally seen most of them obviously doesn't mean anything.
Like Bernard, although I personally have some theoretical concerns about crimped solid conductors (as, apparently, do NASA, MOD and other organisations), I accept that they are used and usually don't fail (just as is the case with screwed terminals), and am not suggesting they should necessarily be 'banned'. However, again like Bernard, the one thing you will never convince me (unless you can find a lot of strong data) is that it makes sense to allow such joints to be inaccessible, whilst that is not permitted for screwed connections. That differential attitude would only make sense if there were very good evidence that the failure rate of crimped (solid conductor) connections is very much less than that of screwed connections, and I really do not believe that such data exist.
Kind Regards, John.
