Errr - how about the same as you so with a single-phase supply, i.e. not in the same DP or 2 x SP Henleys as as the phase & neutral?What are you going to do with the earths then
Who is mst ????so i was right shotgun is mst
Wrong!
Sorry - somewhere along the line one of us has lost the plot...Errr - how about the same as you so with a single-phase supply, i.e. not in the same DP or 2 x SP Henleys as as the phase & neutral?What are you going to do with the earths then
I know that but the point i was trying to get across was if they stop making the single phase blocks as kai suggested how could you do that
I'll put the smiley up for you BAS
OK - if they stop making single phase blocks why would you lose the ability to not put the earth into one?I know that but the point i was trying to get across was if they stop making the single phase blocks as kai suggested how could you do that
Single pole henleys should be banned - what legitimate use (if any) do they serve in the modern environment?
You've never needed to henley a TP&N supply then
2 DPs.....
Why would you want to put the earth into a henley block anyway? Just use an earth block.
2 DPs.....
What are you going to do with the earths then unless you've got a MET bar which is a bit like using a SP henley block
I'm completely missing your point. What has the earth got to do with henley blocks?This has been suggested already but the point was being made about the henly blocks
