I guess by "explain" you must mean "ignore what words are written on the pages of BS7671 and refuse to show in detail how Spark123's diagram contains two individual cpcs because I know that I can't do that".
In what way was it a misuse?
Come on NHA that sort of misreading of posts is beneath you - I said 75% of all the posts you had made on this forum, not 75% of all the topics in which you had posted.My apologies - I must have been confused by the fact that 75% of all the posts you had made on this forum were in this topic, and that their consistent theme was not one of agreement with me..
Come on BAS that sort of misuse of statistics is beneath you.
Can you show me where in any of my posts that i said what you have quoted? stop inventing phrases to back up your ideals, I have shown you the error of your ways, if you choose not to accept that then thats up to you."ignore what words are written on the pages of BS7671 and refuse to show in detail how Spark123's diagram contains two individual cpcs because I know that I can't do that".
You're being obtuse again.Can you show me where in any of my posts that i said what you have quoted? stop inventing phrases to back up your ideals,
I will accept that just as soon as you can label Spark123's drawing to indicate which is individual protective conductor #1, which is individual protective conductor #2, and how you could remove one of the two individual protective conductors to leave one individual protective conductor remaining.I have shown you the error of your ways, if you choose not to accept that then thats up to you.
Feel free to show that when I wrote that, 75% of your posts on this forum had not been made in this post...Alright BAS have it your own way
Each of those cpcs complies with 543-02-09, does it....OK, I have removed one of the CPCs from the top left hand socket, this now leaves one CPC complying with 543 from it to MET terminal 1. The next socket has a CPC complying with 543 connecting it, via the other sockets in the circuit to MET terminal2.
"The" cpc? There are supposed to be two..The CPC did did till I cut throught it!
So neither complies with 543..Now there are two protective conductors each compliantly sized as a single length, but as you correctly say - not as a rfc cpc.
the 16th Edition contains contradictory requirements, viz:
In 607-02-04 said:...shall have a high integrity protective connection complying with one or more of the following:
(iii) two individual protective conductors, each complying with the requirements of Section 543.If you choose to abide by the former paragraph, then a high integrity "connection" (i.e. termination method) is possible only with the use of a separate, additional, CPC.But in 607-03-01 said:...the circuit shall be provided with a high integrity protective conductor connection complying with the requirements of Regulations 607-02 and 607-04. The following arrangements of the final circuit are acceptable:
(i) a ring final circuit with a ring protective conductor. Spurs...
If you choose to abide by the latter paragraph, then the requirements are met by the ordinary CPC in an ordinary RFC, as long as the terminations are made in a high integrity manner, i.e. never with two cut ends of the CPC under one screw terminal.
So which section of the 16th conveys the intended meaning of The IEE?
I cannot beleive this has managed to make 17 pages
But to use what softus posted a bit back as a base as to what I have to say:
(iii) two individual protective conductors, each complying with the requirements of Section 543.But in 607-03-01 said:...the circuit shall be provided with a high integrity protective conductor connection complying with the requirements of Regulations 607-02 and 607-04.
No - it's telling you that it must comply with 607-02, i.e. it must be one of:Perhaps I'm over simplifying, but isn't 607-4 is telling you that a ring final circuit wired using separate terminals can be taken as complying with 607-2, without any further need to thrash out the exact wording?
when you understand what obtuse means then perhaps youll understand what a stupid comment that was from you.You're being obtuse again.Can you show me where in any of my posts that i said what you have quoted? stop inventing phrases to back up your ideals,
Until you do that you aren't really showing me the error of my ways, just that you can't count beyond 1.
