My C/ Heating system orginally had one pump and gravity fed hot water heating the hot cylinder upstairs. About 15 yrs ago we had the boiler moved into the utility room and the hot water didn't get hot as it couldnt gravity feed round the added pipe bends from the utility room into the kitchen before they go up into the first floor and into the hot tank. Its all in 28mm pipe to the hot tank. So the guy who moved the boiler added the pump on the return side and its worked fine ever since.
Recently the pump failed and was replaced with a Primeflow CP 5m heating circulation pump, and ever since whenever the pump is switched on (when hot or cold) it overflows up the expansion pipe into the loft F&E cistern. When it reaches a certain level it doen't get any higher and never overflows the F&E tank as it settles a few inches below the overflow pipe.
This is hot water going into the F&E cistern and wasting energy as well as getting it hot and making condensation in the loft.
Do you think the new pump is too powerful a head rating at 5m, or maybe there is a blockage in the pipework but that seems doubtful as the water in the hot tank gets hot quickly enough. I have added X400 into the F&E tank but not drained off and refilled system yet as I am convinced this is the problem.
Can you buy a low rating circ. pump and if so do you think this will cure this problem?
