Hi there,
I've just had a Vaillant EcoTec 937 installed (the one with the storage tanks) and I'm not happy with the hot water flow rate. I'm wondering if anyone else has had similar concerns.
The combi part is supposed to provide a max 15.2l/min at 35 degree rise (or 65 depending on which brochure you look at), but the storage tanks should (based on my understanding of these things) allow the flow rate to reach a level closer to the cold water flow rate coming into the boiler, like an unvented system. In other words, even if it can't heat the water fast enough, the storage tanks should provide more until they're depleted (of hot water - they fill off the cold water directly, not through the heat exchanger).
So, the cold water flow rate to the boiler is over 25l/min, at 2.5 bar. I'm only getting 10-11l/min of hot water out, regardless of whether the storage tanks are being used or not, or regardless of the hot water temperature I set. This is the same from any outlet (upstairs or downstairs).
The plumbers have checked and rechecked the piping to the boiler, and we've had to Vaillant engineers out who can't find anything (superficially) wrong with the boiler.
I can't get my head around the idea that a storage tank can take water at 25l/min but only draw at 10l/min, even taking into consideration some expected drop from the boiler's internal pipework, that seems excessive.
Any ideas?
Any ideas?
