It's a diy job.
Just a general comment, how reliable is the plumber who upgraded your system? There is a lot of PTFE tape showing on the compression fittings that is not required, jointing compound perhaps but not tape. ...
It's a diy job.
This system worked before yes - I think if I have to slcken the nut I cant do that.It's a diy job
The gate valve is fully open yes I am sureThis system worked before yes - I think if I have to slcken the nut I cant do that.
The plumber came highly reccoemended and is 70 years old - The PTFE is maybe excessive but apart from that its ok no?
I know the horizontal pipe is higher at the left - My point was that the air vent is higher then even the highest point of the horizontal pipe so no air should collect in there?Try putting a level on the 'horizontal ' pipe!
Im so sorry - I just dont understand this - The air vent is higher - The water will collect at the top of the airvent before releasing airIt's simple your air vent is not your highest point!
Air is collecting on that bend.
I really dont want to pay 150 to have a pipe rebent if it wont solve my issue - Please help me to understand your suggestion
Thank you so much
This thread is on page three.The boiler thermostat is operated by a dial at the front of the boiler - It is set to 3 at the moment - I can turn it up to 4 or 5 but I wanted to keep the heating on for longer and at a lower temperature rather than a high temp for short period
I have only one motorised valve which I have set into manual mode
Thank you - I really try and understand my systemThis thread is on page three.
It is time the OP listened and acted on advice the pros have given. We do this type of work every day. Advice given on page one seems to have fallen on deaf ears.
If system is gravity hot water (has that been verified?), circulation to cylinder is going to be poor bearing in mind the flow is 22 ( gravity primaries are normally 28), return is 15mm.
The blockage is the flow pipe itself. You CANNOT Have that shape of pipe. For gravity circulation to work, one has to imagine a circuit where hot water rises and cold sinks
Furthermore, do you know if this cylinder is suitable for gravity circulation?
What is the 22mm motorised valve connected to and why is it not operational
Boiler thermostat needs to be set higher.
How long is the system run to heat water.
is heating and hot water run together? Has water alone been tried?
BTW, why is X400 in the system; system will need flushed several times to remove system debris that thE chemical has lifted
For that colour of water, suspect pump over taking place so flow or return may well be blocked someplaceWater brown and dirty
Cannot see why not. How many motorised valves do you have.Heating and hot water run together - My setup does not allow hot water only
Good controls would keep that in check. Fitted high end controls for a customer with same boiler, her bills have come down while maintaining comfortonly
5) Boiler is set to max temp output and is a gas guzzler - Ideal Mexico 2 125 BED
