- Joined
- 27 Jan 2008
- Messages
- 27,748
- Reaction score
- 3,364
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
2.5mm cable is listed as 18mV/A/m since ohms = V/A then 0.018 ohms per meter and that's both feed and return.
However it is AC your feeding down the cable so the inductance and capacitance will have an effect. Normal method is to twist cable as in telephone cable to counter the effect. However with twin and earth that looks horrid. So twin flex is likely better.
2812X Twin Core Cable is available as 0.75mm and rated at 62mV/A/m so for 20m gives 1.24 ohms and as already said what one can accept will depend on speaker rating but it does look more like speaker cable.
3192Y PVC H05VVH2-F Twin Flat cable 300/500V is same size cable but with a outer Sheath. Also round Tower 2-Core Round Flex White 0.75mm² x 50m is not expensive at £10.50 a role and I would say any of these would likely do the job without using twin and earth which not only looks bad but could be mixed up with LV supplies in the future. You can get 2 core 2.5mm flex but price jumps to £50 for 100m and harder to find in 50m roles.
I think if I was owner of a house and I found an electrician had wired my speakers in twin and earth I would not be impressed even if it worked A1.
With a name like sparkmanc I am assuming it's not for his own house but one he is wiring for some one else? So not only does it need to work but also look right?
