Squeeze box wouldn't be a bad alternative except for one glaring massive dumb flaw.... The need for a PC running server software 24/7 before you can stream your own content!!!
For me and my type of customers this is a deal breaker. Who wants to switch on and boot up their PC just to be able to listen to a track or two? It adds unnecessary cost and complication to an otherwise good product.
Slimserver can be installed on specific Netgear NAS drives, but why when other products work fine with a much wider variety without any special conditions. It's a problem that Logitec (makers of Squeezebox products) know about and they really need to fix it... I'm just not holding my breath on this one.
If one has the time and patience to trawl the info, then get under the hood of the various solutions, then be on hand to keep it all running if something changes then there are workarounds and stuff... but they aren't endorsed so any tech problems won't be supported either. If you want to go down that route then have a look this thread as a starter
LINKYPersonally I'd just rather use a solution that works and get on with enjoying my entertainment.
Since I've been using this site for stuff I haven't got a clue about I thought I'd add something useful for a change
Firstly Chris I believe the SqueezeBox touch can now be used as a standalone server aswell. However, when I recently wired my whole house for AV I went the standalone server route. The Atom based server I use pulls between 13-25w in use and 1-1.5 in standby.
This is coupled with a Squeezebox receiver for each zone, four of which are driven by an STA-1508 multichannel Amp (powered on and off by an intelliplug connected to the server). The other zones distributed at line level and amplified either by my 5.1 Amp (living room) or the TV in that room.
This gives me:
1) Living room zone, powered by 5.1 Amp
2) Kitchen Dining Room zone, powered by TV
3) 2 x Bedroom zones with ceiling speakers, powered by STA-1508 in central hub. (En-suites for both bedrooms have ceiling speakers also, wired to same port on Amp, with a switch in each room and en-suite to disable the speaker).
4) 1 x main bathroom with ceiling speakers, powered by STA-1508 in central hub.
5) 2 x spare bedrooms, wiring run to TV point and ceiling. Ready for future use.
6) 1 x cable run to garden, powered by STA-1508. Haven't got the speakers yet
The above setup with 4 amplified zones and two zones using equipment I already had to do the amplification, can cost as little as £850 plus the speakers of your choice. You can bring the cost down further by using soft squeezeboxes, although syncing may not be perfect:
1) 6 x Squeezebox = £540 (£90/unit)
2) STA-1508 = £180 (manufacturer refurb, ~£350 new or STA-850D @ ~£250 is an alternative).
3) ER1402 = £99 (was on offer, ~£125 would be a more normal price for an equivalent specced machine).
4) Intelliplug = £5
5) Decent Audio Cable = £25
The system has been running along without intervention since install, several months ago.
At the time I was considering the Sonos route, but was looking at a cost of ~£370/zone (zp120's), £2200+ for my setup (again plus the cost of speakers). As the number of zones increases Squeezebox starts to make more sense then Sonos IMO. Especially if you are wiring to a central location and can use multichannel amplifiers, or other devices you already own.
