Yes, I suppose I realised that the explanation must have been along those lines but, when I think about pressures and flows, I'm still extremely surprised. Given that the inlet and outlet orifices are roughly the same size (and even if their were negligible resistance to flow presented by the pipe connected to the outlet), the fact that there is a considerably higher flow rate though that outlet than (if any) back through the inlet, this seems to imply very different pressures in two parts of that chamber which are no more than a couple of inches apart.The "Vanes" on the impeller (lets call them that for now) are angled to move water in a certain way and whilst I can`t quite see from the photo on yours often the housing is not central to the impeller but is set up to be nearer the housing and just past the outlet therefore by closing the gap the water is pushed out. I spent 5yrs in pump R&D before computers were doing this stuff and by moving housings around you get a BIG difference however the wear life on bearings and and other parts have to be considered, well that and the end user of course.
Whatever, they obviously work (and work very well), so my 'surprise' is clearly not really justified!!
Kind Regards, John
