Yes, that's what I thought too.I think you have a hot water cylinder ,with an immersion heater element in it ,and that does not need another tank in the loft.
That blue valve is a gate valve on the rising main and should shut the water to the Cold Cistern ball valve but if it doesn't stop the water it means it's broken and needs replaced. They do have a habit of seizing up over long periods of non use and then the stem snaps inside when they're tried.
The one in the kitchen will have seized too by the sounds of it.
Shut off the mains outside (bottom of the garden path/driveway/pavement) and make sure the cistern stops filling, take that valve off and replace it with a lever valve. Do the one in the kitchen at the same time.
It's an old mains gate valve, hence the blue wheel head on it, they're quite rare as normal jumper'd/wahsered stop taps have been about a long time. Only every seen it once before.
Just be careful, they tend to snap when closed and trying to re-open, because it takes so much effort to close properly it jams the gate in the bottom of the channel.
Yeah, I would like to replace it safely. But then I must close the same valve at the mains rising pipe. This will be tricky because it is hidden under the worktop sink, I could hardly reach the valve from the kitchen floor stretching my arm through the cupboard door, and couldn't apply my best force as I did with the cold tank valve. I might have to dismantle the worktop and the cupboards panels to get access to the valve. This house is about 60-70 years old I think that's 1950s -1940s.
I must also replace the float valve in the cold tank, as it was leaking into the overflow pipe which started the whole saga.
Shut off the mains outside (bottom of the garden path/driveway/pavement) and make sure the cistern stops filling, take that valve off and replace it with a lever valve. then you can do the one in the kitchen at the same time.
Good advice from “oldbutnotdead” regarding tackling the main isolation valve but be aware that unless it’s been altered, there’s a good chance that the incoming main could be lead with the original isolation valve “sweated” onto the lead pipe.
Best to strip out and expose what’s what, you may need a plumber to work on any lead pipe if indeed there is any.
Pop a couple of pics of it onto the post and we may be able to advise better. If you're at all worried about the mains stop tap then don't touch it until you know you can isolate it from outside first.
