- much like "I will vacuum the room" - an impossibility (not even really a verb) in the normal home.
Yes I remember being told the wagon which cleans the streets is an air velocity cleaner, without the moving of the air, it will not take up anything, with them there was at that time with the Johnson the most well know make a gap of 1/2 inch around the bottom of the unit.
However if I go to most retailers of cleaners and ask to have a look at their selection of air velocity cleaners they will look at me with a blank expression.
When I wanted to find an example of the unit required to work the lamps, I put in the words "LED Driver" and then carefully selected one which had a fixed voltage of 12 volt and was DC and had a current large enough to do the job. The "LAP" lamps all seem to state 50 Hz on the lamp, but non seem to say AC or DC in the
screwfix catalogue. Only the picture of the lamp actually say it is AC
and even that does not actually say AC it says 50 Hz which must be AC.
Until this thread I knew there were some DC only lamps, these in the main are for caravans, however I did not realise some were designed to be AC at 50 Hz, as to if the 50 Hz is to show not suitable for use with the standard switch mode power supply, i.e. for use with a toroidal core transformer, but why are they not suitable for a DC supply? You can get "electronic transformers" which now can go zero to 60 VA but not at 50 Hz.
Likely the only problem with using "electronic transformers" is where the unit will not work with less than 20 VA. Those which will work from zero will likely still power 95% of the LED G5.3 MR16 12 volt lamps. Only those designed for 10 ~ 36 volt DC for use in caravans would have a problem with the high frequency output.
However and this is the real problem, we don't know.
