ideas/inventions
How are you going to show that Newton, Faraday, Planck, Dirac, Einstein and many others far to numerous to mention were doing it all wrong? Stoooopid. :rolleyes:
well that's exactly where you jumped in with both feet... with major assumptions... i have a pretty simple scientific notion that i think should be reworded (or similar... as i can't describe any more without giving it away) that's all i want to do. The rest of science is safe....
All or part - the same principle applies. Publish a paper, get it peer reviewed and if it's successful it'll be included in the major journals and you'll get the credit for it.
Thank-you for a decent answer. So how and where do i publish a paper?
First you'll need to learn how to write a paper - there's a specific format required. It'd probably be easiest to find a specialist writer to help you with that and guide you through the whole process.
Ta. I'll get googling tomorrow.
But a specialist writer might nick his "big idea" and get all that money. :LOL:
imamartian said:
I'm asking for advice on how i might protect my thoughts about changing a particular scientific notion.
Will this "scientific notion" have any commercial value or is it pure science? The answer isn't always obvious. :confused: :confused: :confused: To take a hypothetical example, you might have an electromagnetic theory of gravity which subsequently turns out to be the key to warp drive! :eek: :eek: :eek: If you can see the connection already, you need to build a warp engine and get it patented (more on that later). But if it's pure science with no apparent application then this --
TheOriginalTonkaToy said:
You submit them for publishing as a paper in a scientific journal. You wait for the peer reviews which will test your methodology and ideas and if it's accepted, you get the credit.
Expect to be challenged - that's how science works. You build a theory and then do your best to destroy it - if you can't then the peer review process allows others with a more objective view (you can't be truly objective because you have a vested interest) to attempt to do so.
pretty much says it all. Contrary to popular belief, experiments aren't designed to confirm theories but rather to disprove them. :eek: :eek: :eek: Scientists are always looking for counter-examples.
You should start by reading the journals. :idea: :idea: :idea: Search out anything related to your theory. You'll get an idea about the required format (which isn't difficult) and you might find that your idea has already been done. :( :( :(
If your idea has commercial possibilities you'll want to do things differently because once you publish it you can't patent it. That's where things get really tricky. It's a pretty safe bet that you don't have the facilities to build a warp engine - or a teleporter - or a fusion reactor (which has been done by the way). The fact is that even for simple inventions with no new science involved you need a product champion, some organization with the recourses to build and market your idea. The whole process is a minefield of which I know nothing. Best of luck! :) :) :)
