the whole idea/setup is laughable.
In fact this is the general difference between us, when I don't know something I will ask. If I know something about the subject I will recount my experience. Please explain why it is not a viable concept.
PhilipClarke, I'd love to take this idea further,I think it's a great idea.
You and me might hook up? PM me.
Yes - but the air in the loft will be hot in the summer, when no one needs the air heating.So you agree then that for 50% of the year the loft is hotter than the house and therefore can be used to heat up the air. The "it's not posssible" argument has been disproved by Nuire in one of the preceeding pages.
Neither did I - the fact is that in the winter, the air in a loft will be at or below freezing for a lot of the time. Therefore useless, since the air will be substantially colder than the rest of the property.No-one suggested freezing the attic space in winter at any point.
If you honestly believe that the airflow created by a sub £10 extractor fan connected to 45m of flexible duct will even be noticable, then you are deluding yourself. There is also the significant issue that a cheap fan designed for occasional use for short periods will very quickly fail if left switched on for hours at a time.I thought that the air resistance would be a problem too, but it's not, the manrose specs suggested that it would be, but presumably they require that the fan maintain a certain pressure on the outlet, hot air being less dense probably helps too.
All of which are carefully designed & approved and are used in such a way to minimise bacteria growth. They also cost far more than your 'instant and cheap' option.Water is allowed to be preheated in low pressure heat exchange systems already.
In that case, what is this?what you are saying is that the heating of water would not be allowed in an open tank system which was never suggested. .
using the heat to pre-heat the water from the ground supply to the hot water and therefore reduce the energy required to run a bath or shower. Retro fits would be particularly good for this especially if they still have an old gravity fed (but unused) tank in the attic like my current home.
As is often the case phil, academics often have no idea of real world practice/common sense
Knowing that hot air is less dense and is trying to rise would add to the problem of trying to push it downstairs, no?I thought that the air resistance would be a problem too, but it's not, the manrose specs suggested that it would be, but presumably they require that the fan maintain a certain pressure on the outlet, hot air being less dense probably helps too.
There is no need to do any of that. The basic idea is wrong.Seriously, you and flameport if you didn't believe that 20 watts was sufficient could have placed more than one fan in the ducting and done a cost analysis compared to solar power, you could work out from a home radiator how long the boiler is required to be on to increase room temperature by 1 degree Celsius compared to how the energy required to move preheated air, while range of things could be done rather just rubbishing the theory
Using heated water to heat the air is far, far worse.Yes and that section was for using the retrofit as a heat sink so that the hotter water would continue providing hotter air through the night, it was not mentioned at all that an enclosed mains flow would go through it.
Whereas in the UK we don't even try to make things work as this thread proves.
In the winter, when heat is required, the air in the loft will be freezing cold.
In the summer when the air in the loft is hot, you don't need the heat.
adlplumbing said:1 as pointed out winter when you need heat the attic is cold
2 preheat system already exsit ic called solar and works all year round
3 running fan electrical money saved on heating via gas will not be
made up as electricty is more costly than gas(gas power station)
4 other methords of conserving heat are better such as loft insulation
or new type double glassing and their know at type of render which
can be retro fitted to old housing stock
5 finally their one thing you missed we use to air to heat people house it
now considerd old hat as it was not very good
thatbloke said:Also blowing hot air into a cool room would cool the hot air rather than heat the cool air would it not?
I hope it works out for you Philip , the new build market might benefit from something like this and glass roofs might be an idea but I dont think I'd like ducting running all over my old place.
big-all said:basically you are talking about a system that will only give a return for a few weeks a year when the conditions are exactly correct
without sophisticated control you can easily have a negative value because your gains depend so much on the output off the sun and the wind direction and rain all very unpredictable as we know
