But the nominal voltage did, and there were implications of that.Either way it won't matter as the actual voltage in the UK never changed anyway.
Yes indeed, the main one being people now using the wrong figures in calculations.
That is essentially true, since it is a arbitrary creation of paper-pushers which has no physical/engineering meaning. If 'they' assert some nominal voltage (whether it be 240V, 230V or 600V) then they can't be 'wrong' - maybe stupid, but not 'wrong'!It is simply impossible for the nominal value to be wrong.
There are multiple acceptable spellings of some words.Like someone used over 400 years ago?
Things change.
That's the way it works.
Get over it.
Then I declare that the nominal value of the standard single-phase supply in Britain is 600 volts, with a tolerance of -58 to -64%. It's impossible for that nominal value (with the declared permissible tolerance) to be wrong, but obviously it would be absurd to specify it that way.It is simply impossible for the nominal value to be wrong.
Things change.
Get over it.
Get over it.
I think you'll find that it is you who is wrong and absurd.It's impossible for that nominal value (with the declared permissible tolerance) to be wrong, but obviously it would be absurd to specify it that way.
As I keep saying, a lot of the problem seems to arise because, in the case of electricity supply voltages, the word "nominal" seems to be being used in a sense which differs from how it is nearly always used in engineering and many other fields.Nobody, or hardly anybody, agrees with your bonkers refusal to accept what "nominal" means ...
That would have been their hope, although there would still have been a finite probability that some customer would end up with only 11 (or 14)!ie 12 -0 +1 (nominal)
Sure, but that's just like the sugar - just as a consumer is not going to be worried about their "1kg" bag of sugar containing 1.3kg, nor (in the sort of applications you mention) is an engineer going to be concerned about a "100 μF" smoothing capacitor having a capacitance of 120 or 130 μF. There are, of course, countless other electronics situations in which one is equally concerned about positive and negative deviations from the 'intended/marked' value.There are instances of tolerances in electronics work being somewhat asymmetrical about the nominal value, as I'm sure you can think of John. Electrolytic capacitors are a good example ....
Sure. I would imagine that they aim at around 120 μF, and then label it as "100 μF -20%/+50%", for the reasons you mention. Aiming for 100 μF and thereby ending up with a component of, say, "100 μF ±35%" might well be regarded as potentially having too low a capacitance for the application. They could, of course, simply label the usual "100 μF" component as something like "120 μF ±35%", but then user would have to do the thinking... where due to manufacturing constraints it's not unusual to find a component, especially in larger values, with a declared tolerance of something like -20/+50%.
As Detlef suggested earlier, I can but presume that it was thought that, in our case, existing equipment/appliances might not function satisfactorily at voltages below 216.2V (i.e. between 207V and 216.2V), so we needed (a lot of!) time to allow any/all such equipment to come to the end of its natural life before our supply voltage was allowed to be as low as 207V. Similarly, at the other end, some existing equipment in "220V countries" might not be happy with voltages as high as 253V.Precisely - There's good reason for the asymmetric tolerance which is often applied to electrolytic capacitors due to the applications for which they're used. But there was no good reason for adopting the peculiar asymmetric tolerance of 230V +10/-6% for mains supplies.
