Hi. I've been on here for a while, but this is my first post!
My home is run off a private water supply, from a well at the bottom of my field. Its pumped using a water pump beside the filtration system outside.
Now, the house is an old croft, which has a traditional heating system (gravity fed) using the cold water tank (25gallon) and expansion tank (4 gallon) in a cupboard upstairs (no loft).
The hot water tank is in a cupboard on the otherside of the wall from the outside Oil boiler.
Now, the pump outside runs whenever the pressure drops below 2 bar and stops when it reaches 3bar.
If, say I were to flush the toilet then wash my hands in the sink beside it (Only 1 toilet in the house) and switch on the cold water tap, the water pressure reduces dramatically and actually stops filling up the toilet cystern until the cold water tap is switched off.
I've got the house in pieces at the moment, doing every room up so I was thinking of changing out the hot & cold water tanks for a Main's Pressure Hot water tank (Megaflo, for example). Will this improve my water flow for the cold water too, or will I need a larger pump outside to increase the water pressure initially?
I'm new to this plumbing stuff and loving it! I can get a registered plumber to install the system, of course.
Oh and I stay in Scotland (for the regulations side of things)
Thanks all!
Thanks all!
