- Joined
- 27 Sep 2022
- Messages
- 242
- Reaction score
- 18
- Country
Don't know but see attached extracted from a manual for indirect. I have read a term mWC (meters water column). This is similar to mine but a bigger tank volume (500 litres). I am assuming mine with a lower flow rate than 6.5m3/hr would have less mWC (~1m?).what does mSS mean
Its a heat only boiler with no pump inside it. I have bought an external wilo pump (pico) with 6m head.heat only boiler then that 6M Wilo will also be fin
Not sure about pipe size to use and hence the question: should 22mm be fine considering the boiler has 22mm flow and return pipe to it. or go with 28mm pipe.
