Thanks. All this could have written up front to save hard work for Hard-Work. Avoid one liners.
All this gas been written before. Use the search box.
I do try the search box, but sometimes it takes a lot of searching and still failure.All this gas been written before. Use the search box.
Modulation range is a weak point, but the robustness of the boiler offsets it somewhat.
Other manufacturers moved away from the concept because they couldn't get the HEX right. Potterton, wooshitter, Ferroli, Ideal have all tried it but screwes it up with either construction, materials or layout.
Plus, the cynic in me thinks the spares sales aren't doing them any harm.
I believe the fan is another. Makers advertise that a boiler has a max flue length of say 6 metres. That is a great selling point for versatility and should sell more kit. The fan has to be man enough to exhaust the gasses out of the flue pipe at minimum fan speed (assuming the fan does modulate) and maximum flue length. That may mean a burner's gas rate can be quite high. If they did not have extended flues they may get away with a fan that can run down to a very low speed giving a very low burner output. As you say lots of points dictate this. But a variable burner and fan designed for all flue lengths and associated controller may be just too expensive for a domestic unit. They may need models only for long flue lengths, by inserting a beefier fan.That particular french boiler is an atrocious piece of equipment. We're planning to pull a pair out of respite home soon as the maintenence is ridiculous.
There are lots of things that dictate modulating ranges. Burner being one.
What is the Intergas modulation range compared to the competition?
If there is less range, how much does this affect the efficiency
thought the whole idea behind modulation was to use the least amount of energy required
Is this the trade off with the intergas design, more reliability less modulation
Is that another reason manufacturers moved to their current designs
Thanks, that is interesting.
What is the Intergas modulation range compared to the competition? If there is less range, how much does this affect the efficiency?
I thought the whole idea behind modulation was to use the least amount of energy required for the specific output (or something like that, I am coming from a laymen perspective here).
Is this the trade off with the intergas design, more reliability less modulation?
Is that another reason manufacturers moved to their current designs, it gives more flexibility to control modulation but at the cost of reliability.
Sorry for repeat questions, just trying to work out all the pros and cons.
To add to Dan's excellent reply. Constant on-off operation is inefficient. It wears out the controls more. There is a lot of inefficiency on the start up of a hot boiler. The start cycle purges the burner chamber with cool outside air ensuring no gas is hanging around, as it does this it extracts heat from the heat exchanger with the cold air moving over the heat exchanger via the fan dumping it outside, until the burner lights up.Thanks, that is interesting.
Many thanks. Most informative.
So I presume combis are at their most inefficient when people use the hot water tap for short hand washes?
One brand can achieve 10: 1 with an ordinary pneumatic gas valve and a simple variable venturi which they've patented, been around 6 years, no problems, have one myself.
