Is that 10:1 a veissman as that is anther brand I had considered.
No, Vokera, which is what we're referring too. Viessmann is ooverpriced tat like most German engineering.
I just read from Vokera that the lowest modulation is 2.8kW, 3.2kW and 3.6kW for their 28, 32 and 36kW models.well the way I see it OP if they have had a Vokera fitted in the prop for over 20 years ??
& it has given good service why not replace it with another vokera
They also make a Vokera with a 10.1 modulation ratio. Unica I . 28,32 or 36 Kw out puts & the Linea
Thanks for post.20:1 is admirable but if you have a max heat load of 15kw it's unlikely a property's loss would ever be 0.75kw.
A lady friend has just moved into a studio flat. Kitchen and l/room in one room with separate bedroom and bathroom. The combi was a no-name job, well one I have never heard of. It is a Procombi. On Googling it is made by Vokera. It must be 2 or 3 years old. It is simple with a rail burner and a recuperator. Those things they slapped on regular boilers to convert them to condensing boilers. To me Procombi looks like the bargain basement, buy in B&Q, made in Turkey range of Vokera keeping the old production lines open.I work for Vokera.
It modulates down to 14kW, so with a small studio flat cycling is inevitable and it can be heard clicking on and off. I can see that only on a warm up would it be above the minimum modulation level. The flat looks like 9 kW max would heat it. I told her about the boiler. She said the first signs of trouble she will throw it out and fit a branded model. The installation looks fine, with `maybe` one thermo-rad valve in the bedroom. The pipes under the floorboards may be undersized but I really don't know unless the boards are lifted. I said I would top up the X-100 in case.
If it did pack up, one with a wide modulation rage is essential in this flat. The question is.....is this a reliable combi?
Thanks Dan. I just thought. Many people buy many `quality` products because of the reliability factor. I know many buy Neff for show in the kitchen, which is brand snobbery. In the flat in question, the visually excellent condition 2 or 3 year old fridge/freezer has packed up, so she is buying a branded make rather than pay a lot to get this no-name fridge fixed. In the flat all appliances on show are Bosch and those out of sight, dishwasher, combi fridge-freezer are bargain basement appliances.We fitted a Unica donated by Vokera for a charity installation and I was looking at it thinking "why would you spend 3 times this on a Viessmann?
Thanks VC. It looks like this. The 25kW job as it only does one showerPro-Combi's are made for a wholesaler for a price range. At that age it might be made in our factories none of which are in Turkey, or it might be a rebadged ideal. Manufacturers are asked for several thousand boilers at a set price and the best bid gets to make and badge them for the customer.
We actually don't make them but they are made at the parent company's factory on the same line. It does sound like one of ours similar to the Compact HE. I love them, simple boilers, very little to go wrong except the PCB which is expensive until compared to a Viessmann but they're very rarely if ever serviced properly although you could say that about any boiler.
Don't just think about power which is important for hot water production and wide modulation range which is important for low heating loads, think about whether the water supply coming into the house is sufficient. It's pointless putting in a 15.6 l/min Linea One or 14.6 l/min Unica 36i if you only have 12 l/min coming into the house.
As for reliability depending on the offers and model they are warrantied for 5,7 or 10 years all on the proviso they are serviced every year.
I picked up on this point. Looking at the combi, it is a simple rail burner, so the heat exchanger does need a brush run over it. Apart from that, the rest appears to checking burner gas pressures and as they say in the car industry, give it a `walk around`. It is very simple. She is thinking of getting a British Gas contract for piece of mind.but they're very rarely if ever serviced properly although you could say that about any boiler.
you say the Unica looked as good in build quality to the Viessmann with the cases off. But I would presume the Viessmann had higher quality and more reliable components, giving it the edge in reliability. As BMW`s have higher quality components to say a FIAT.
VC, I think you contradicted yourself inadvertently in this:
`We actually don't make them but they are made at the parent company's factory on the same line.`
True. I had a super reliable Toyota (made in England), and the alternator went dickie (Bosch). I stripped the alternator and cleaned it all up and it worked again.You have fallen into a trap there..... For example, they both use the same pump (boilers, not BMW). My last car was a Honda Accord. Made in Japan. The only unreliable parts were the expensive German ones.
I have not a clue.Who are Vokera's parent company?
VC thanks. I Googled and Riello own Vokera. Riello have a good reputation for commercial burners, oil and gas. Do Vokera do the British Gas call out type of deals? I assume it is better going to the makers rather than British Gas who have to deal with every maker. The makers will probably have the part in his van. I get it that Pro-combi do not source from Vokera any longer and this model is `obsolete`.Let Dan reply about the Viessmann and quality. They're a boiler like any other and perception is all.
The existing boiler would be sold by Pro-combi with a 2 year warranty and they were phased out as it is a Band B boiler three years ago.
Pro-Combi have documentation on their website.
There are slight differences between ours and theirs so don't use our documentation.
When it's serviced make sure the recuperator is cleaned and the condensate pipe checked.
We do the servicing and warranty calls for Pro-Combi anyway. You could ring our customer service dept and maybe they'd offer a service, around £80 I think.
Yes, I suppose it's a contradiction but when we were privately owned the factory made boilers to our spec. Then we were purchased by the group that own the manufacturer who now design the boilers and we get a UK spec but the parent can do their own deals to sell a slightly different spec under a different badge in the UK.
Pro-Combi and Sabres (for another wholesaler) are now made by Ideal I believe. I stay away from sales so although I was told who the wholesalers are I let it drift.
