Bernard why were they doing this? If the draw-off from a combi is lagged there is no problem with DHW delivery, unless there is a long dead-leg.
Correct, and Bernard did not have to post these figures for us. However the data, methods of analysis and systems are open to scrutiny. What also has to be taken into account is the ongoing service costs. Cylinder systems, unvented and vented have more parts involved which are future failure points adding more costs. Unvented with their annual service costs. One good point about Ferroli Modena and Intergas combis is that they use far less electricity in summer when only supplying DHW - the pump is not used. But the overall annual running and services costs matter with an eye to expensive failures in the future - cylinders, 3-ways valves, cylinder stats, etc, when they add no extra value over a well made, well designed, well sized, quality combi.It's not obligatory to agree or disagree, someone was asked to supply data, he did as best he could and a little better than the usual anecdotal data we're fed.
how does the atag compare to your other favourite boiler https://www.diynot.com/diy/threads/navien-combi-boilers.507427/A quality combi? ATAG iC Economiser 39 Plus
Very well. But I do not go to sleep with the manual under my pillow yet. I have a few favs of course. ATAG Control system is getting simpler. But very expensive to buy.how does the atag compare to your other favourite boiler https://www.diynot.com/diy/threads/navien-combi-boilers.507427/
What kW size?I have an Atag IC Economiser and it performs very well. DHW output is excellent.
Here it is:D. A. Wulfinghoff, Energy Efficiency Manual, Energy Institute Press, Wheaton, Maryland USA makes for interesting reading
Overview of the Navien for you:how does the atag compare to your other favourite boiler https://www.diynot.com/diy/threads/navien-combi-boilers.507427/
