The man is an utter arse. He's not even measuring the right pressure
Please to everyone, do not encourage him. They get worse when you do.
Two at least are GasSafe, or maybe three of them.
Bernard do not answer the active loon he will get worse.
You do need to be a bit more careful with the accuracy of some of your posts. Unless the valve seat / seal is damaged a TRV in the OFF position will prevent water flowing through the radiator it is fitted to.
I will ask for permission to quote.
great stuff Shall i order in more popcorn during your extended information intermission
TRVs are irrelevant, I never even mentioned them. He doesn't know how a zoned heating system works, and that if one zone is off you are not using gas to heat it. You can see why plumbers have a bad rep.You do need to be a bit more careful with the accuracy of some of your posts. Unless the valve seat / seal is damaged a TRV in the OFF position will prevent water flowing through the radiator it is fitted to.
TRVs are irrelevant. He doesn't know how a zoned heating system works and that is one zone is off you are not using gas to heat it. You can see why plumbers have a bad rep.[/QUOT
A bit like turning a Trv then
That’s nothing like what you said. Now you’re arse licking Bernie. Bless
Why don’t you explain how in the “Off” position a TRV still supplies heat.
If you do I’ll donate 1k to any charity you wish
Do you mean if the heat is on elsewhere but the TRV off?
You are still heating unoccupied areas even with TRVs. Now you know.
