E
EddieM
thank you Lower..
I have refilled the coolant bottle about 5 times but each time after a few miles the bottle is empty again..
I sealed the leak of the coolant pipe with proper sealant from car shop. The old pipe was not even leaking it just looked corroded and rusty which I found out its just surface rust and common on these engines on those pipes. I didn't even need change pipe in first place.
there seems to be so leaking for that pipe, everything seems dry and if it was leaking Id see it under the car ( no under trary fitted ) also it only seems happen under load not idling. at idle the level in the bottle seems steady and doesn't reduce.
I am consideirng if the hg has gone, to fix it myself. I would take my time with it and buy a cheap run around car to get me back and forth while fixing this one.
If the head gasket has gone (check the filler cap, may have brown creamy gunk on it, which is an oil/coolant emulsion)
The the gasket has probably failed due to the cylinder head itself being warped, so probably not a head gasket change.
Also, you could put some drain indicator dye in the coolant and use a UV torch which might show where the leak is. From what you've said though it's pouring out so of there's no puddles on the floor then it's going into the engine.
