I recently fitted a new socket to my living room which is attached to the main ring which I located under the floor.
I tapped into the ring with a 30A junction box which is attached to a floor joist, and then ran the spur to a double socket which I chased into the wall.
Have I broken the law by this DIY or is it legal? I only found out about the regs on DIY after the deed and I am having a bit of trouble establishing if its legal or not.
Also if it is legal could I do the same in my garage which has a seperate consumer unit from the house but only has two double sockets running from it
Cheers
Joolz
Cheers
Joolz
