I will try with the first one before we cut but I honestly don't think there's much chance of it working, most of the conduits run for at least 10m and through at least two right angles. I will try and let you know though.
Check out my wee beastie
Lightweight.I do my soldered joints by pre-tinning the two conductors, then soldering a binding wire to one conductor and using it to bind the two tightly together and then flow solder over the whole area ensuring it wicks through to the other side.
Lightweight.
There are some far superior methods of making a mechanically strong joint before soldering here: http://www.markhellerelectric.com/solder.pdf[/QUOTE]
Yes, I've seen them before. Overkill!
And using those methods with 2.5mm^2 is pretty hard and produces massive joints.
