Oh yes you do.you don't need a room thermostat
So in your airtight house you live cheap but die young.means keeping the windows closed!
Why?Oh yes you do.you don't need a room thermostat
But you don't. Once written (and it's old tech now) software is free. Mfrs like to sell something extra that's material, with a clever-sounding name.There is no point saving £100 on gas if you have to spend an extra £1000.
To close the control loop. WC alone is open loop. The internal house temperature is the thing you're trying to control. It's ridiculous to not have a sensor telling the system what it is.Why?
Not at all. The outside temperature is NOT the only thing which determines heat loss ina building. People do emit 750 - 1500 watts each. Large modern buildings with lots of office workers don't need any heat at all, they only need cooling, because of the number of people in them.You are just posting guesswork
I and others have answered the OP, the discussion has moved on.You guys are not helping the OP or contributing in any useful way to the goal of conserving energy.
I can see the logic in that. Fitting an external sensor, by itself, assumes that the external temperature is the only factor affecting the internal temperature.You need a room temp sensor
A rapid change in outside conditions takes time to affect the inside of the house, so WC alone, gets it wrong.
Have a party with 20 people each losing a kilowatt, and WC gets it wrong.
Leave a door open for ten minutes, and WC gets it wrong.
Well, given that the heat lost through wall is proportional to the temperature difference between the inside surface and the outside surface, a sensor on the outside wall is a pretty good indicator. I suspect that most domestic heat is supplied when it is dark, so we can neglect solar heating.Fitting an external sensor, by itself, assumes that the external temperature is the only factor affecting the internal temperature.
A sudden drop in the external temperature may not mean a sudden drop in the internal temperature. It all depends on the thermal mass of the building.Well, given that the heat lost through wall is proportional to the temperature difference between the inside surface and the outside surface, a sensor on the outside wall is a pretty good indicator.
At the risk of appearing messianic , a sudden drop in external temperature will set up a thermal wave in the wall. Closed loop control will have no hope of preventing a drop in internal temperature. Only an open loop control factor has a hope of keeping internal temperature constant.A sudden drop in the external temperature may not mean a sudden drop in the internal temperature. It all depends on the thermal mass of the building.
Waves have momentum, a thermal gradient does nota thermal wave in the wall.
Back to your original question, eh?Now, given that I can buy a boiler and the KW's are not an issue, which boiler would you recommend?
The size boiler you require is determined by the flow rate of the cold water entering the house. You can measure this at the cold water tap in the kitchen using a marked bucket and a watch. Work out how many litres per minute you get.Firstly, can I get a 24kw boiler that will give better flow so that I can feed a shower directly from it. Or will I have to get a boiler with more KW's?
If I get a 28kw or even a 32kw will there be a vast difference in flow rates for the hot water?
If you want to go down the weather compensation route you need a boiler which has W/C capability: Main is not one of them.I'm thinking "Main" if I want to keep to budget but if I decide to blow the budget, possibly a Viessmann.
Presumably the price you give is from an online seller. Prices do not include the Flue, which will be at least another £50 depending on how long it needs to be.I've just had a look at one of these Broag-Remeha Avanta Plus 28c (Combi Boiler) for £758, is it a good boiler and price?
