I'd agree with this, if you tightness tested and it was ok, and you've listed the appliances that you were requsted to test, and whether they were safe or not, you've done what you should. List any other appliances you see and mark them as "not requested to test".there is no requirement to check all rooms on a landlords safety check.. if you see the fire then you need to act but if you dont then you have done what you are required to do..
And if you miss or don't list a cooker with a drop down lid, then it may call into question your tightness test.
and what exactly makes you believe your required to carryout a tightness test.
I thought a tightness test was mandatory on a landlords.
* THE GAS SUPPLY
* gas appliances
* gas flues
* ventilation
oh dear,
lets fill in those holes.
gents if this was the place to discuss which really it isnt id recommend a good read of the regs,paying particular note to the following
pg 65 guidance 219
26.9 and the 4 items
appendix 1
what a landlord should offer and the work required for a safety check are quite different.If you think because a form says something it must be done your very much mistaken.
oh dear,
pg 65 guidance 219
appendix 1
