- Joined
- 27 Jan 2008
- Messages
- 24,691
- Reaction score
- 2,830
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
It seems we no longer measure electric in kilowatts, it is now measured in homes? 1.4 kW = 1 home.
Yes, I was well under 1.4 kW average, for a 5 bedroom home, but not heating with electric, and my EVs are two e-bikes only. The headline was
"Hydro scheme powering thousands of homes for 60 years" I consider the two power stations I worked on, Sizewell 'B' 1500 MW (2 turbines) and Connah's Quay 2400 MW (4 turbines) and compared with them, 49 MW is not very much.
I look at the power required for my pond pump, which is very low, the most powerful water wheel in UK Quarry Bank Mill near Manchester was 100 horsepower, = 75 kW so water power is not that high, I am sure it can easily be worked out, the limit is governed by rain fall, and catchment area, but I look at lakes like Vyrnwy, which has many roles, main is Liverpool water supply, but it is also used to reduce flooding of the Dee and Seven, however being able to decide if water released to Dee or Seven does not really help, as heavy rain will swell both rivers at the same time.
Someone has to juggle how much water to store, the more stored the less the flood control, the less stored the more likely we will run short of water, add the need to generate electric as well, and likely someone at some point will drop their balls.
Anyway, just looked, and I am getting about a home's worth of electric from my solar panels. Rather a dull day.
looking at my own usage last monthBBC News Wales said:49 megawatt capacity means it can produce enough electricity to power the equivalent of 35,000 homes
