sijaysee said:
i think that the questions that i have asked here are quite valid
Not for a qualified professional to ask.
and there IS a lot of confusion over bonding etc
A qualified professional should not be confused.
espescially when the rules change as they do
The rules haven't changed for a long time.
for example i am told by certain people here that when i supplementary bond the bathroom , then it should be contained in that room.
Yes, it
should - what's confusing about that?
yet reg 601-04-01 states "the supplementary equipotential bonding may be provided in close proximity to the location" .
Yes, it
may be provided in
close proximity to the location, as an
alternative to being provided
at the location - what's confusing about that?
not exactly what i was hearing from you pro's. not "must" or even "should" but "may". so do you see my point?
I assume you're referring to this?:
Lectrician said:
all bonding muct be done in close proximity to the bathroom.
I agree - it could have been clearer. I guess he meant "close proximity" to mean a perimeter beyond which you shouldn't go, i.e. "all bonding must be done in, or in close proximity to, the bathroom".
I take it from the quote that if i cross bond the basin taps and then take my 4mm from the light pull switch to the shower pull switch and then to any cold water pipe in the house then thats complying with that reg.is that correct?
No - because "any cold water pipe in the house" is not the same as "in close proximity to the location". Take your supplementary equipotential bonding conductor from the cold pipe to the hot pipe and then to the pipe supplying the shower (assuming all these are metal pipes, and fed by metal pipes), and then to the cpc at the light pull switch and then to the cpc at the shower pull switch. (Or whatever sequence of connections makes sense given the layout)
