That's strange. Lsst time I tried that it didn't work. In fact this forum's software fails to recognise a lot of the BBC tags. I will try again.Apparently there is
No indent
IndentIndent=2
Kind Regards, John
No indent
IndentIndent=2
Nor did we, but we certainly used the mnemonic, seemingly effectively (given that I still remember it best part of 60 years later!)Apart from the obvious connection, we never used triangular diagrams with that mnemonic ....
Nor, really, can I., I can't even see how the stupid Ohm's law triangles could even be put to use here.
Sir Olivers Horse am Ambling Home To Olivers AuntNor did we, but we certainly used the mnemonic, seemingly effectively (given that I still remember it best part of 60 years later!)
Nor, really, can I.
Kind Regards, John
I suppose, as it was always written for us in a triangular form, that is the only way I can 'see' it.Nor did we, but we certainly used the mnemonic, seemingly effectively (given that I still remember it best part of 60 years later!)
SOHCAHTOA
O A O
S H C H T A
Yes, I'm pretty certain that it was the former ('purely as' the series of letters).I suppose, as it was always written for us in a triangular form, that is the only way I can 'see' it. I wonder how you imagine it?
Purely as
rather thanCode:SOHCAHTOA
Code:O A O S H C H T A
The problem with SOHCAHTOA is actually trying to remember the correct letters as it sounds like SOCKATOWER (tow as in towpath)I suppose, as it was always written for us in a triangular form, that is the only way I can 'see' it.
Purely as
Yep, next-to-impossible to remember that spelling. That's why most of us turned it into a phrase. The one I learned and remember (appropriate for the 60s!) wasThe problem with SOHCAHTOA is actually trying to remember the correct letters as it sounds like SOCKATOWER (tow as in towpath)
and even sock it to her (sound like sock it 2 {h}er) which at the time was a phrase in common use and fitted with local corruption of the spoken word.
He presumably hadn't noticed that his 'cleaning up' had 'gone wrog', such that what he had found was an expression for 1/N, rather than for N.As an aside to this my grandson was doing some homework: let's sayView attachment 300124and needed to find N
so divided by MView attachment 300125then cancelledView attachment 300126and cleaned up View attachment 300127He could not see what he'd done wrong,
Oh my goodness, just remembering another which I think was:... She's over Him, C##t above Head, Tits over Arse.Yep, next-to-impossible to remember that spelling. That's why most of us turned it into a phrase. The one I learned and remember (appropriate for the 60s!) was
Some Old Hippy Caught Another Hippy Tripping On Acid.
The first few of the others that a Google search finds are:
Some Old Hairy Camels Are Hairier Than Others Are.
Some Old Hags Can't Always Hide Their Old Age.
Some Old Horses Can Always Hear Their Owner Approach.
Kind Regards, John
As I said in post #66, in my student days, the letters of mnemonics usually got turned into 'memorable (but 'unspeakable') phrases' a lot worse than that oneOh my goodness, just remembering another which I think was:... She's over Him, C##t above Head, Tits over Arse.
ICODE are for "inline codes", monospace blocks that appear in the flow of a paragraph. Normal CODE are for blocks.. That icode wrapper around the code block will probably ruin it/cause the [CODE tags not to be interpreted as a block. Not sure why the software is putting them in if you hit edit; it doesn't for me. On other forums I use with this same software, there are separate buttons for inline code and code but on my phone at least I see only one.Am I doing something Wrong?
10 PRINT "Hello World"
20 GOTO 10
RUN
PRINT
causes one message to appear but then the GOTO
locks an infinite repetition of it so the screen floods with the messageCode boxes and quote boxes look similar, except for the font and the wording in the header. Looks like it's working as expected for youI can only get it right in what looks like a quote box.
I'm sure it's just a perspective thing, but I can't think of a good use for an indent! (other than a list, which has its own tag set)has an 'indent' option, which seems an obvious thing to have!
Thanks for this, I've also been doing some Google work and everything I've seen agrees. You have now explained why it appears like:ICODE are for "inline codes", monospace blocks that appear in the flow of a paragraph. Normal CODE are for blocks.. That icode wrapper around the code block will probably ruin it/cause the [CODE tags not to be interpreted as a block. Not sure why the software is putting them in if you hit edit; it doesn't for me. On other forums I use with this same software, there are separate buttons for inline code and code but on my phone at least I see only one.
When we talk about software (which is the usual use of these things) a program snippet might appear in CODE and then talking about individual lines is done with an ICODE so it doesn't break the flow of conversation, for example:
Your basic program looks like this..
Code:10 PRINT "Hello World" 20 GOTO 10 RUN
TheGOTO
It's probably just down to my entrenched 'writing style'. When I'm writing documents or, indeed, e-mails, I will often indent things to make them stand out as 'different' from the rest of the text. Admittedly, I most often do so with quotes, URLs or equations etc. , which can be dealt with in other ways with this forum's software, but I also use it for 'paragraphs of less importance' (i.e. "read this only if you want more detail") ......I'm sure it's just a perspective thing, but I can't think of a good use for an indent! (other than a list, which has its own tag set)
