Prince Philip - Legend
He's my heroPrince Philip - Legend
One of the problems of living in an old house is that a ton of other issues crop up meaning every job turns into 5 jobs!At long last I bit the bullet and re-plumbed the radiators in the bedroom and the lounge below the bedroom. In 2011 they were plumbed in 15 mm originally as a quick fix to get the cottage heated. The 15 mm drops to the lounge were T'ed from the 22 mm with the T's partly below floor level. It worked but was far from "elegant" The large hole hacked in the flooring was needed to get the two T's in place.
After installing a radiator in the second bedroom using 13 metres of 8 mm ( 6 flow and 7 return ) and finding the flow was more than adequate the use of 8 mm for the lounge and main bedrooms radiators was going to work. The construction of walls and floors made the use of 15 mm impossible.
Using Pegler Linear manifolds to take the 22 mm down to four 8 mm pipes and using just 2 of the four pipes made the task very easy.
The 22 mm flow and return are above the floor in the bedroom due to differing floor levels between rooms.
The soldering is not the best
It wasn't posted out of pride, merely to show the DIYers and people thinking of using a plumber that alternatives to "standard" pipe work with Tees and Elbows do exist.Certainly nothing to be proud of. One day I might be as skilled.
Yes it is being "boxed in"I fooking hope that's being boxed in! Even then.
There were many other things with higher priority that needed to be done.4 1/2 years to achieve that!
No, slightly less than that for the pair.Did it cost £84?
It had to be a search engine as I haven't the space for a complete set of plumbing brochures in a book case..4 1/2 years of googling and thats the result.
Bullet manifolds are available in various sizes 22mm> 8mm
its actually really easy using the bullet manifolds
Perhaps I should have looked for 8 mm press fit couplings
bernard green said:Perhaps I should have looked for 8 mm press fit couplings
No such thing.
