hello all, i wonder if some one can help me understand this question. ( im not a electriction but like to learn!)
What is the reason that we have to put the live and neutral a certain way around in the u.k?
The bit that i dont understand is that when abroad you have a two pin plug that you can put in a socket either way around so this must reverse the neutral and live does it not?
Also when last at my place abroad i had to fit a new socket and took my tester with me that checks for earth, neutral and live faults ( cant remember the name of the thing but is a black square with 3 lights on the front with a u.k plug molded into it ) Now when i pluged it in it showed 3 lights to indicate the plug was wired correct, so i turned it upside down but it still showed all 3 lights saying that all was wired correct! how is this possible if it can tell if the live and neutral are the wrong way around?
