Depends where you are, who you get and whether you get them in on a callout or as a scheduled job. If you can arrange things (safely) so you can run for a few days without using those sockets (extension cable(s) from the cooker point socket, plug them in one at a time) you'll get a much better rate.
And without knowing how far it is from kitchen to CU and how the cables are routed it is a bit tricky to determine how long it would take to do the worst case and throw a new cable in. Budget £200 (as a job, not as a callout) and keep your fingers crossed.
BEARTRAPS.
Some electricians will tell you 'oooh you need a new consumer unit mate, that one's too old, needs to be metal-clad now'. Untrue- if you are replacing the thing then yes it has to be metal now, if you're not replacing it then it only needs to comply with regs as they were at the time of installation.
'Ooh, this needs an RCD on it, your old CU won't take one, have to have a full rewire, metal box, etc etc'. Again untrue UNLESS the electrician installs a new cable that is buried less than 50mm behind a wall surface (there are other getouts but generally if the wire isn't on the surface then THAT CIRCUIT will require RCD protection. That can be achieved in several ways, only one requiring a new CU.
'Oooh, this is all old, need a full rewire etc etc'. If they say this after spending about an hour with some test gear actually measuring the performance of the wiring then have a think about it and remind them that they're here to fix the absent earth in the kitchen. If they say this after opening the CU and seeing red and black wires (assuming we are on PVC and not the old rubber or lead sheathed stuff) then take with pinch of salt.
Good luck- me I'd have had the lid off the CU by now and then be lifting floorboards looking for shonky junction boxes (kitchen extensions were notorious for shoddy bodges by kitchen fitters)
