Well I was thinking the bitumen felt would self seal around nails. I mean will be two layers and also feltingProbably, you're relying on felt which is gonna be penetrated hundreds of times.
over the counter battens
Soz Woodleg, thought it read vapour check.Lol. Is that where you put them when you tile a roof?
It's a standard way of dealing with this type of situation.
If anyone has an alternative method to using tiles or slates below their design pitch, then let's hear them.
Why? If we don't know of an alternative then nailing through the waterproofing layer is suddenly foolproof?It's a standard way of dealing with this type of situation.
And very common on many older properties, I guess you only get to see the felt ones though.
Yes, I specify materials designed for the situation.
I wouldn't, specify a product unsuitable for the situation.The Client OP requires a slate roof below its recommended pitch.
Specify that.
