Hi all,
I have a 2018 Worcester Greenstar i combi boiler. No water tank. 1960s bungalow. Radiators replaced about a year ago.
I've set the flow temperature to 55C in the belief that this is an efficient setting that allows the boiler to run in condensing mode. I also have the TRV valves turned up high on my radiators (4-5) in the belief that this will allow as much heat to be released as possible through the radiators for the given flow temperature.
Is my understanding correct and is this an efficient way to use the heating system? I find that the room temperature is comfortable doing this. Having the radiators set lower means some of them start cooling before the temperature is how I want it in the rooms (not sure how accurate the TRV thermometers are for the rooms as a whole?) Besides which, if gas is being burnt to meet the demand set by the thermostat, which is in a cooler room, might as well make best use of that heat through all the radiators?
Thoughts?
Is there a diagnostic check I can do through my boiler to check what return temperatures are?
Thoughts?
