It is a compromise. Nothing is perfect.Therefore to apply earthing to parts which cannot become live because they are not part of an electrical appliance or accessory is not beneficial.
Some seem to think that live conductors can suddenly jump out and attack random pipes - we do not have to cater for this.
Now we take a hypothetical installation where the sparky has been round and done his bit. And the sparky determined that the water pipes didn't need any earth or bonding connection. What's more, none of his cables are on/close to any pipes.
Then the plumber comes round and puts the plumbing in, and like many plumbers, doesn't seem to care about cables. So somewhere there's a cable sat on a hot pipe. Over time, with the heat and movement, the insulation slowly wears through until fate decided that the live conductor which happened to be on (the wrong side) contacts the pipe.
Because someone didn't cater for it, we now have live pipework with only the boiler wiring to "earth" it - hence an inadequate fault current to make the breaker trip in a timely manner.
But it's alright if anyone dies in the ensuing fire, because it wasn't the sparkies responsibility to account for that - or that's how I read your statement.
If you want to earth all your isolated metal parts, I suppose that is up to you.
You then happen to hold a faulty appliance flex while touching one of these (wrongly) earthed parts and get a shock greater than you should.
What then?
So, would you remove your wrongly applied earthing after RCDs have been fitted?Of course, these days the circuit will almost certainly have RCD protection. That's not the case in older properties that haven't yet been upgraded.
Please offer an example.But I believe the regs disagree with you.
No. Bonding of extraneous-conductive-parts is required.Bonding of conductive parts in a bathroom IS required unless certain conditions are met.
Overlooked the extraneous again.
That does not include isolated conductive parts.
Then you are mistaken.That sounds very very much to me like those who wrote the regs consider that the electrician MUST cater for the potential of a live conductor randomly attacking a pipe.
