A
AssociatedAlarm
Get a multimeter and stop moving wires and guessing.
So today I have purchased a multimeter,
What should I be checking on please, could you guide me?
With thanks,
Doobie.
For a start.You can check polarity. Continuity, Correct voltages. On both the panel and peripherals.
Polarity, is the correct way around for the connection.
Continuity, is the cables being solid without a break. So join the ones in question with power off.
Voltages, how much voltage is at the bell, the pirs the panel power outputs.
Peripherals anything else connected.
You could also do a MA reading to ensure the panel is not being overloaded.
So following the above if you find no continuity in the pair, you have a broken cable.
No power a fuse or broken cable. If power at cable and when connected it disappears a faulty unit.
So sorry you did not know or could not be bothered to find out the common terms used.
Try this to help http://www.allaboutcircuits.com/vol_6/chpt_2/3.html[/QUOTE]
Thank you Associatedalarms, that is helpful. I will take your kind advice and do some reading. I will try out testing the items you have suggested.
Doobie
with multimeter set on dc range you should get 13.80v dc typical across aux volts, battery terminal and hold off + and - also if your tamper return was ok 13.80 across hold off + and tamper return. check and come back to us.
