I doubt a DIYer would pull out the certs and read them before swapping switch, even if he could find them
Depends on the layout of the house surely
You're the one that can see the future
The RCCB is the main switch (for that CU). There would be little point in having a second next to it.
I agree - and would have wired it so that it was as you say - a lot easier to do than the way it is.I do feel that it ought to be identified in some way as one of the "main switches", though, not just as a "test regularly" RCD. It's not entirely unreasonable to guess wrongly that it is downstream of the clearly-labelled "main switch, turns off all circuits" switch in the other box.
537.2.6 ???Isn't there some regulation about this?
Well I hope you realise now how important it is to test ,and prove circuits are dead before working on them. And how UNSAFE it is to ignore parts of electrical installations.Yes, a small 2 or 3 switch secondary breaker was added last year to power an upstairs shower.
I felt safe ignoring that little one, though, as :
A. I didn't see how it could affect the bedroom light switch, and
B. The secondary takes its power from the primary, which I had fully switched off.
Indeed.I think there should definitely be a warning label - but I wouldn't have done it like that, so...
Yes, that's also true. However, the unwary/unknowing might not realise that the circuits in the outhouse/whatever were not disabled by operation of the Main Switch in the main CU (which they might think 'disabled everything in the installation').True, but that is unlikely to supply some of the house circuits.
I'm sure you are right.I doubt a DIYer would pull out the certs and read them before swapping switch, even if he could find them
But I wasn't talking about the OP reading the cert now, but about him having been told what had actually happened when the work was done and remembering that.Mmm not sure, in my experience certs are stuffed in a drawer or filing cabinet and forgotten until the insurance man or estate agent asks for them
Yes, you are right. If he had been told that the lights had been moved he is absolutely guaranteed to have forgotten that.Ok it may happen but once the job is done most folk forget the detail,
