Great news! my shower now works again.
Thanks for the useful hints!
Once you take out the three screws, the case front will come off.
Obviously make sure the power is off before doing this!
I found the procedure for swapping over the TCO straightforward, although getting the old one out was a bit fiddly.
I got the part from Shower Doctor (http://www.showerdoc.com) who were helpful about what I needed, and very quick to send the part out.
You may need some "star" screwdriver bits. I already had a set of these.
Use a flexi bit screwdriver with a T10 torx bit.
Providing you can get in the space. I've never used that type on this sort of job.
But this is what i was talking about.
FLEXI BIT HOLDER
FLEXI BIT HOLDER
Three terminals on the TCO had a cables attached via screws.
back terminal [two green, earth]
left terminal [one yellow?]
right terminal [three yellow]
The 3 blue (neutral) wires connect to the centre bar joining the 2 elements.I also had to remove the screw that held back three blue wires on the element to enable better access to the TCO for removal.
