I told you it woudn't take long! - glad you've got it sorted.Couldn't resist it - so headtorch on and out I went. 10 minutes later - we have light!
Kind Regards, John.
Fair enough, I am not the most fervent believer in the nanny-state and , indeed, I have helped you, I hope, however the fact that the light 'works' is not the only criterion in an installation.especially how bloody dangerous it can be if not handled carefully.
I suspect I have a feed problem.
As you know, I have been party to helping you sort this out. However, once the forum's resident 'incompetence policeman' wakes up, you're probably going to get some flak. From the point of view of some people, the most worrying thing is probably that you would not have made the mistake you did had you understood how an RCD works - so they would question whether someone with that 'basic lack of knowledge' is actually safe to be doing such work. They will probably also question what other mistakes (with not so obvious immediate effects) you may have made, and will undoubtedly also point out that you will not have had the equipment, and maybe not the knowledge, to undertake tests to confirm that your installation was safe.On the subject of regs..... I did try going the 'legit' route on this. .... I lost interest in pursuing and went for homemade. After all our plans were all the same. .... That said I am more than happy to listen to opinion on the subject. I'd not like to even pretend I am an electrician but I am a degree level scientist with a decent grounding in physics and hence know most of the whys/wherefores of electricity - especially how bloody dangerous it can be if not handled carefully.
A wise decision. Bun fights never achieve anything, particularly when one of the participants does not understand the concept of giving up!I did write something here about ego and certain rather negatively-minded contributors but I've edited it out. I don't need a virtual bun fight.
I agree with all that.The comment about understanding RCDs is very fair. I should have a better knowledge of what these actually do and I should have acquired this knowledge before getting into fitting this one. I'll spend some time reading up on this subject. Much like so many things in life one only really gets to find out exactly how something works when the need arises. I would just say though that if all everyone ever did was to pay someone else to do everything that was even remotely challenging there'd be very little learning going one in this world.
You are ignorant, incompetent, and doing things which are dangerous and illegal.
I fear you don't have half a brain.
Have you lot seen what this degree level scientist has in his new garage?
//www.diynot.com/forums/viewtopic.php?t=289043[/QUOTE]
Must be a troll, surely?
Neutral from the main CU runs into the neutral bus bar above the RCD in the garage unit. Should I be running this neutral feed directly into the RCD instead? If so where?
Whilst I do subscribe at least partially to some of those views, it was apparent that by the time you came here for help you were already so far down the road that you clearly were not going to back-pedel and have the work re-done professionally - so the only sensible pragmatic approach was to help you.
... and please note that I am saying all this as a non-electrician.
Kind Regards, John.
Edit: I see that the aforementioned person has, indeed, woken up whilst I was typing this!
Unfortunately too many un-informed DIYers will ignore the advice to "get someone in" or will get someone who is cheap and probably just as un-informed to to the work.IMO, the pragmatic approach wasn't to help him energise the installtion - it would have been pragmatic to advise he get somebody in to do it properly.
