I am looking to move a radiator from the rear wall (under window) to the side wall within the room as I am installing french doors.
Ironically, this was the previous position of the radiator. As I result, the holes are pre-drilled into the floor and I am positive the pipes are just below.
Rather than lifting up the floor boards (tongue and groove), the void beneath the ground floor is pretty decent (around 60-70cm).
After going under myself and crouch walking to the correct location I found that, as suspected, the pipe work was cut at the old rad positions and extended with compression valves. It is the last radiator in the run it seems as it only has two pipes directly feeding each side. They do not branch off any other pipework. Is that common with the last radiator in the run?
So, If I felt I could do the work myself I would need to
1)Drain the system
2)Cut the existing pipework ensuring the existing holes are directly above. If this lines up with the compression joints, so much the better.
3) Fit elbow compression joints
4)Poke up the copper pipework and fit to the elbow joints.
5)Ensure the pipe work is secure (retaining clips to joists or wall).
6)Re-attach Rad in new position.
7)Fill system
Anything I have missed or should look out for.
It looks as if the radiators was moved position via the void last time. The floorboards have no damage and the compression packets were left in the void as well as spare pipe.
If I felt that I was in over my head, my additional questions is....how many plumbers are prepared to go into a void to do work? Would this be refused as an option? I only ask as I prefer this to cutting up a floorboard.
Many Thanks in advance
1)Drain the system
7)Fill system
