- Joined
- 19 Jul 2007
- Messages
- 5,949
- Reaction score
- 1,143
- Country
Feet, BTUs.
Dinosaurs!
Older houses were built in feet & inches so why not use them.???
My "Mears" is imperial so works well.
Feet, BTUs.
Dinosaurs!
Dishman, if the rad is too tight to the wall, then try turning the wall brackets round 90degrees, this will push the rad further out from the wall.
And fit some rad foil whilst you do it.
It would very slowly give off the heat it had absorbed, so there is no effective heat loss to unwanted areas.
If you feel you know so much then why seek advice for something so simple???Technically the heat is not wasted from a thermodynamics point of view. The same amount of heat will eventually be given off by the wall. Heat is only wasted (from a home efficiency point of view) if it is emitted in an area that is not useful. Hence, if it is an inside wall, you will not lose any heat. The same principle applies to storage heaters. The bricks eventually emit all the heat they absorbed in the first place. There would be no net loss of energy at point of use.
Cut the joist.I was looking to replace it with a 2000 x 700 but there is a double joist in the way. So it is either 1800 or 2100. I think the latter will look too big.
You don't say number of external walls or if this is a bedroom/living area.The room is 4.9 x 3.8 with a room hight of 2.5 and an window area of 5.36. This gives me results of around 1800w. Those with experience agree?
I suspect you can do this yourself. Take a cushion and dust sheet down there with you.
