- Joined
- 25 Jul 2022
- Messages
- 18,975
- Reaction score
- 1,625
- Country
Look at the information you supplied. I'm only going from thatWhat makes you conclude that? It’s easy to track the vessels and see that they are mostly off the coast of Dover
You need to dig deeper in to the numbers, you also can see the operational data on public AIS tracks.21% of those rescued, 3% of their rescues , guess statics not you strong point .
Would you prefer that they didn't respond to calls in the Channel?A teenage life guard paddling out to a swimmer on a surf board does not cost the same as a £million+ off shore life boat with a full crew.
What about the full costs in London/Thames?You need to dig deeper in to the numbers, you also can see the operational data on public AIS tracks.
Each rescue does not cost the same.
And where is busier ?Inshore rescue and river rescue boats are smaller inflatables they cost 1/10th - 1/50th of the cost of the all weather off-shore class.
Typically 2-3 people on a 50-250k rib.
Scandalous.In 2022 alone, the station had its busiest year as the crew launched 734 times and saved 21 lives.
The objective is to save lives. 21 saves this year. Well done to Kevin and his team. What a great job done with some modestly priced RIBs. Sadly not the busiest by any shot. Just 1/5th of those saved in or about French waters.And where is busier ?
Station manager Kevin Maynard said: ‘Since the station originally opened in 2002, we have made the best use of the space available but now, thanks to generous donations, we have a purpose-built lifeboat station which has been specifically designed for our needs. It will make a huge impact on our lifesaving service in central London.’
Over 20 years since its formation, the crew at Tower Lifeboat Station has saved 381 lives across 9,901 shouts* – just a couple of weeks ago, it became the first RNLI station to reach 10,000 lifeboat launches while saving the life of a member of the public.
So all those cancelling their contributions are obviously affecting the busiest area
Dig as deep as is needed to select the criteria that you want to argue your point.You need to dig deeper in to the numbers, you also can see the operational data on public AIS tracks.
The point is, they are spending money they can’t afford, losing donations they need, rescuing criminals who should be stopped from even getting in their unsafe vessels.Dig as deep as is needed to select the criteria that you want to argue your point.
It's known as confirmation bias.
Do you think they should stop doing that? Your silence speaks volumes.rescuing criminals
Yes. Our Government are failing us badly.who should be stopped from even getting in their unsafe vessels
Kevin the taxi driver?Well done to Kevin and his team
