I just tested the new unit in position, opening it with the Samsung unit by invoking DHW.
It opened in 12.8 seconds
- the old one takes 12.5 seconds when not in a pressurised system on the bench.
Seems pretty much the same to me
>CH circulation pumps are well known for getting 'lazy' as they age.
The point is, why ? and is my old one actually "sluggish" at all ?
The reason for raising this thread is that I had to do a lot of work to completely fit that valve, and I really can't perceive what was wrong with the old one.
Simply labelling it "lazy" or "sluggish" doesn't point up the difference in behaviour that the Samsung controller is throwing an error on.
us.megger.com
Thanks for digging that up, Madrab. It quotes an earlier "Motor Mayhem" blog, which I am unable to find an existing link to.
But in that article it quotes the reasons for "failure" as one of 5 factors:
I don't feel any nearer understanding why the ASHP controller was throwing the E911 "insufficient flow"error.
Why do electric motors fail?
5 Reasons Why Insulation Deterioratesus.megger.com
- Contamination – If a chemical deposit gets into the windings, deterioration is very possible. Makes sense though, right? Chemical spills are usually not a great sign, and a good reason to panic. Unless – of course – you dropped a gallon of H2O or a pound of C12H22O11 on the floor. No need to panic, just grab a paper towel (or 50) or call your dog into the kitchen.
- Mechanical – Over time, vibration or movement in a motor’s windings (or the motor itself) will wear down the insulation system.
- Normal Thermal Aging – With normal operation, a winding’s insulation will naturally deteriorate – albeit slowly – throughout its lifetime. That’s just normal (expected) wear and tear, folks.
- Overvoltage Spikes – Switching, lighting, and VFD designs can all cause high voltage surges, which can lead to insulation aging.
- Early Thermal Aging – Ah, we are back to the topic of excessive heat. A hot motor is not a happy motor. If your motor’s winding temperatures are on the rise, premature motor failure is right around the corner too. Of course, you already know this because it was the very first sentence of this very blog.
- Contamination There is none in my old unit.
- Mechanical 1000 minutes total run time over those 6 years ? - not credible
- Normal Thermal Aging – With normal operation, just normal (expected) wear and tear, folks. see Mechanical
- Overvoltage Spikes voltage surges, which can lead to insulation aging.
This could have validity, as the valve is powered (but not actively running) when fully open.
Difficult to know whether really applicable in a normal domestic setup, so not really testable. - Early Thermal Aging the topic of excessive heat. A hot motor is not a happy motor. My old one never got above 90°C
