It will obviously be a different product to the one pictured.
Then it would be against their instructions.
I didn't see the bit where they specified any particular make or for that matter anything other than double pole switched fused spur outlet with a 16A fuse.Then it would be against their instructions.
I assume this is aimed at me.What?
Why are you not just arguing that the 16 is a misprint?
To say that the MIs must be followed and then stating this may be achieved by doing something other than what they say is ludicrous.
I agree wholeheartedly with your post, Half the time he doesn't even know it's for a boiler and probably wouldn't 3A in it even if he did know.But point is the electrician provides the FCU for the guy fitting boiler, and rarely even sees the spec for boiler, he may never even see what boiler is being fitted, so in the main it is down to the guy fitting boiler to check fuse size and RCD type. Electrician is rarely on site at same time, even if he arrives after to fit the FCU he is rarely given the boiler instructions, he assumes 3A, but he often does not know.
I agree. Sunray cannot have it both ways.The photograph clearly shows a standard UK FCU and asks for a 16a fuse in it. The switch fuse Sunray suggested is not the same and would not be following MI.
If it is not a misprint then it must be a mistake.As to 16a being a misprint I don’t think so as it is a 16a oven.
What is a "16A oven"?If it truly is a 16A oven then it should not be connected to a 13A FCU.
Is there an online copy of the instructions?
Ah that depends entirely on what the appliance is.What is a "16A oven"?
If you mean an oven which has a maximum load of 16A then, as I don't need to tell you, a cooking appliance with that maximum current represents only an 11.8A load after diversity.
I don't really see any conceptual difference between a cooking appliance with a maximum, load of, say, 50A connected to a 32A MCB (which I presume you would think was fine) and one with a maximum load of 16A being connected to a 13A fuse, do you?
Kind Regards, John
I'm not trying to have it both ways. The MI asks for a 16A FCU, all I've done is googled for 'fused switch' and the very first hit happened to be the one I quoted and it happened to be rated in excess of 16A and therefore would not create a safety issue.I agree. Sunray cannot have it both ways.
Agreed in principle.If it truly is a 16A oven then it should not be connected to a 13A FCU.
If it could be fitted to a 13A FCU with a 13A fuse then it should come with a plug.
Exactly.What is a "16A oven"?
