- Joined
- 23 Nov 2014
- Messages
- 19
- Reaction score
- 1
- Country
The other night I switched on my electric fire, and it made a loud bang and tripped the MCB. The same thing happened 11 or 12 months ago, but at that time a bulb inside it shattered so I simply replaced the bulb and all was fine until now. However this time, when I flipped the MCB back on everything was working perfectly and there was no obvious reason for the trip at all.
Yesterday I got an electrician in to PAT test the fire, which he said is absolutely fine. He then ran some tests on the sockets and has picked up some sort of fault - there is a low current detected even with all appliances unplugged, suggesting that two wires may be too close together and causing a short circuit? The mystery is why it isn't tripping the RCD (which was confirmed to be working) and why the MCB tripping seems to occur as a "one off" before everything works again.
The electrician is coming back in the new year to do the full electrical safety test, as that expired a few months ago. He did suggest it odd that the previous test, done by the previous owners of the house, only lasted 5 years and not the usual 10. He mentioned that perhaps some sort of problem was picked up then.
I am so worried that this will turn into a huge job with replastering and the like
Any ideas much appreciated! The house and electrical system are about 18 years old.
